Tailgate locking mechanism
sib8292
The tailgate on my s2 has started opening of its own accord when driving and the locks don't always engage when closing it.
The electric release is working OK.
So I assume its down to an adjustment of the lock mechanism itself; any tips please?
Hi
I had a problem with my boot mechanism last week as well, please see this thread for all the helpful advice i received... http://www.porscheclubgbforum.com/tm.asp?m=166468&mpage=2&key=&#167655
Having fixed my boot, i realised that the right one wasnt actually workign very well, and i managed to fix this by lossing the nuts that keep the mechanism and the drainage pieces in place. You may also have an issue with the rods, but you will see this when you take the carpet up as suggested by Graeme in my post.
The boot catches often play up at this time of year becuase of all the gunk that flows through them. In their wisdon Porsche designed the drains for the hatchback to flow through the latches????? [&:] Thereby regularly washing out all teh lubrication and causing them to jam every now and then.
I've got into the habit of removing the latches at least once a year, cleaning them out with WD40 and then lubing them up again with 3 in 1 oil before refitting. Takes 30 mins tops and is well worth it. Extravagent people could just buy new latches which are only £20ish each [8|]
When I first read this post I was like " man that sounds bad... glad mine doesnt do that! " So sooner had i uttered the words but yes you've guessed it mine is now popping its tailgate at every oporunity it gets.... I've started to recognise the signs just before it pops... when Im sat at the lights I can "really hear" the car behind me I just drive on and park as soon as is safe and by the time I've got my seatbelt off "whoosh.. up goes the lid" time to get the wd40 out!
