Tailpipe causes erroneous readings?
John Sims
PCGB Admin
Following my problems at JAMSport, I was given to wonder if the position of the exhaust probe in the tail pipe could effect the readings taken. Here are my thoughts, what do you guys think?
I have an Essential Styling "" Janspeed oval rear section exhaust. The construction is such that they have a perforated pipe of 2" dia running through the rear silencer with, in effect, the tail pipe squashed can welded to the rear face of the silencer box. To my mind, if the probe is only in the can section, not in the full flow area of the pipe, it may read erroneously:-
Low revs "" low exhaust gas velocity. Gasses flow out from the 2" pipe into the tail can and, without the velocity to project them, accumulate within the tail can.
High revs "" high exhaust velocity. Gasses projected out of 2" section and clear the tail can completely due to high velocity. If the probe in the tail can is out of direct flow of 2" pipe it could end up in a low pressure area where it is not reading correctly.
I'm sure the above is complete rubbish and JAMSport have such exhausts all the time, but it did seem strange that there was a lot of unplugging, re-plugging and checking of the sensor during my run.
Tony "944Turbo" has the same rear section as me but I don't know if they were paying as much attention to his read outs as there wasn't any reprogramming underway.
They put their hand inside the large section and fed the probe into the smaller section on mine and yours. On mine the probe blew out so they wedged it into yours with wood.
The sensor has to be unplugged and purged with clean air because when a vehicle is running rich the read head gets contaminated very quickly. There was a large cloud of black smoke billowing behind your car, which reduced through the runs, but even at the end every lift off gave a good size puff - EFF?
Hope that helps!
Tony
Thanks for that Tony. It does help considerably and also confirms my thoughts about the importance of getting the sensor in the gas flow.
Good news - going to play with Andrew & Wayne on the 5th in Cheshire to get it all sorted, so I looking forward to the run home. [:)]
