Tall Driver Advice Please Guys
- Thread starter Nick7602
octupe
Nick7602
Your a newbie like myself, you've joined a really good group, I've had some great feedback to my various threads
Like you im a tall guy 6'3" tall, I have lowered the seat down as a far as it will go, my car is a 987.1 and I find that the steering wheel still hits my legs, Im actually considering buying a flat bottom steering wheel to over come the issue, in my opinion the seats dont go low enough and not enough variation in positioning of the steering wheel, im wondering if there are seats that will go lower without being bucket race seats?.....and does anyone have an aftermarket flat bottomed steering wheel fitted to their car and if so which one?
Again thank you for all and any responses and for taking the time to read my thread.
Nick
Assuming you have got to the point where the seat position cannot be improved, then I would suggest trying the seating in a few other Caymans to see if there is an option that works better. I am only 6’ 2, but did not need the full rearward adjustment on my old Cayman R or my current GTS.
You may not gain as much from a flat bottom steering wheel as you would with seats that gave you a bit more rear travel. You should be able to get the back against the rear bulkhead. But you may have to accept a slightly more upright seating position, which would obviously drop your knees a bit.
If all else fails, a bit of time tryping as many cars as you can to see if you can find a configuration that works and you can duplicate. There are plenty of alternative seats out there but trying to measure differences, with a combination of seat and fitting system to consider, will be challenging.
Where about are you based? There may be others local l to you who can help.
John
AndrewT
I hope that someone will correct me if I’m wrong but I think I was told that the optimum steering wheel height and reach can be found by adjusting it so that your arms are horizontal and your wrists rest on the rim - I hope I haven’t remembered that incorrectly?
AndrewT said:I hope that someone will correct me if I’m wrong but I think I was told that the optimum steering wheel height and reach can be found by adjusting it so that your arms are horizontal and your wrists rest on the rim - I hope I haven’t remembered that incorrectly?
That always works for me Andrew.
Jeff
Nick7602
My driving position is quite upright, and prefer my arms bent very similar to a rally driver whilst steering, someone once mentioned and I quote" its as if you are wearing your car" I will explore the seating position some more, however I might invest in one of these http://www.girol.it/porsche/ from a couple of chaps who have these im told the quality is excellent, I think this might be a better link : https://www.spacershop.com
Again thank you guys for responding to my curious if not odd question
Nick
gronk1967
https://youtu.be/72qpgA7Cr_4
gronk1967
If you said you had a 986 I would have said you may have had a problem but (87/981/718 all seem to be a little bit bigger where it counts for us taller drivers. Enjoy your car!
I’ve solved the problem by fitting an OMP Corsica 330mm dished wheel. It’s slightly smaller diameter than the stock Porsche and also the Momo wheel so gives plenty of clearance. The dish, plus boss, also help to bring the wheel A little nearer, which I find more comfortable.
I think the best advice I’ve seen on this thread is to try a few options before you make any major changes.
S
