Tandem Pump
jac997
My 05 997C2S has sprung an oil leak near the rear wheel(drivers side). Looking at some forums it appears to be the tandem pump? Is this a common fault?
I think that the problem is more common than you think, it happened to my friend's 997 and the only cure is a new pump. The pressed steel cover that rots through, from the outside, is not available seperately. Just to be sure he gave the (relativly unprotected) steel cover two coats of Hammerite before it was fitted.
Also see here...........
Porsche 997 rusty, corroded tandem oil pump. Early 997s are showing signs of heavy corrosion to the engine tandem oil pump - located on the right hand rear of the engine (centre of pic). The casing corrodes badly and requires change before the rust becomes so bad as to perforate and cause catastrophe.
21 May 2012
Sorry, the photo doesn't seem to want to paste, see here......http://www.brauntonengineering.co.uk/porsche-news-devon.htm
ORIGINAL: tony1066
Completely agree but unfortunately I can only comment on the ones I have heard about or reported to me.
Which means that it could be six or seven years old. [&:]
You'd hope that the OPC network would see this issues developing prior and go with a preventative maintenance, however it does seem that at that age many cars drop out of network- or even any maintenance program. Not all admittedly
garyw
