Tappets
- Thread starter colin944
bmnelsc
Looks like the 944 lifter assemblies are little more complex but given the price of new ones - sounds to me like its worth a try.
david924s
VW part number 050.109.309 (J) although think the (J) is replaced by an (H) now. Only difference was the oil way groove and the oil hole to base measurement but they pumped up fine as the oil feed in the head has a lot of tolerance.
Porsche dimensions
Diameter 35
Piston head (internal) 11
Piston to base (internal) 7.5
Height 25.5
Oil hole dia 2
Oil hole to base 10
VW dimensions
Diameter 35
Piston to base (internal) 6.5
Height 26
Oil hole dia 2
Oil hole to base 10.5
Although they were genuine VW they were the same manufacturer as the only Porsche ones you can get now
timmyturtle
If i remember correctly he just tapped them on a piece of plastic and they came apart.
He said you should do that whenever you take them out for a while.
tartan_rob
Any more details on how this is done?ORIGINAL: tartan_rob
I have re-built my engine and I stripped down and re-built the lifters. It is quite easy once you have done one but you will need space, chemicals and some tools. Took me about 4 hours to do the lot though. Easy and satisfying job.
