lesworth
My drivers door doesn't shut as well as the passenger door (springiness and alignment). From what I can tell the top of the triangle door window (forgive me not knowing the correct term!) fouls slightly on the door / windscreen seal and the front of the door capping also looks like its fouling on the seal. I gues with most targa's of this age, the seal has been replaced at some point and maybe not fitted correctly. How adjustable is the seal? Would it be easy to 'seperate' just the affected area and re-glue?
Also, when closed, the door sits proud about 1/8 of an inch. Could this be the seals or perhaps the striker plate could be adjusted to remedy?
Any thoughts or similar experiences most welcome...
