Targa top
- Thread starter Guest
bones
Southbound
ASk for David.
engleflick
If you are talking about the little curved black brackets at the front edge, you can by replacement ones from www.type911.co.uk. They also list some stronger/longer ones which are supposed to improve the sealing, but I haven't got those so I will reserve judgment. If you get some let us know how you get on[
plhorner
Moderator
I think Southbound will recondition your top for you (01264 810080), I don't know if they do an exchange service though. However, unless its obviously the top its self, I'd have a look at the condition of the seals and the actual fit of the top. I understand it is completely adjustable.
New seals aren't cheap, but old ones can be rejuvinated (to an extent) by smearing with vaseline, this helps to re-hydrate dried out rubber and also lubricate.
HTH
bones
What it is is the clip has worked itself back. If you undo the two screws slightley on the clip the whole thing will move front to back and left to right by about 1cm. The clip is attatched to a metal plate throught the other side and under the outer vynel (It isnt worded quite right, sorry but if you do it it will become apparant).
Just move the clip as far forward as it will go and this should solve it.
Neil Eldred
I have the same problem, and cannot find anything to adjust to better it, also the nearside rear dowel pin has snapped leaving it hanging but still fits in the hole. I cannot find anywhere that can supply one, having looked at all the usual recommended 911 spares sites etc. It is currently in a garage in an attempt to spot weld it, but I really dont hold much hope, and it leaks in heavy rain. (84 targa)
Regards,
Steve
bones
Kenny ask your Reg' Sec, if he can recommend someone in the area, you found out the hard way there are many 'experts' out there.
I plastered 1/2 pot of vasaline on the seals during the summer, and they are in pretty good nick - its just the **** top that the pain. It locks down ok at the front, but as Kenny says, it leaves a lip that makes for wind noise at speed. I'm sure that my rear dowel that has snapped is why I'm getting leaks from it ill fitting at the rear. Any advice welcome!!
Steve
I've done quite a bit of work to try to improve my targa (added thinker, rubberised clips at the front to successfully reduce wind noise, built up the worn frame at the front with epoxy to improve the clip fastening & reduce wind noise, added old cycle tyre inner-tubes to the side seals to reduce the gap between seal and window!!!) but still have a small water leak.
The resistance I get is good when I clip the roof on, but I think water is running down the channel between the two pieces of rubber and into my car!!
I live in Herts - any chance of meeting up for your opinion?
I live in Herts - any chance I could
