Without divulging into too much detail, my oil pressure sender unit had died and was left to my mechanic to fit a new one whilst MOTing and servicing my car. Unfortunately my cars been returned with a new sender unit and an oil leak from the mounting block caused by threads being stripped from the engine block and the unit not tightening up enough to form a seal under pressure.......Anyway, my engineer brother is fairly hopeful we can fix the problem without having to remove the engine to tap a new thread in.....so my questions are please:
a) The sender unit scres into an alloy square block carrier. This is secured by a large nut - does anybody know the factory torque setting for tightening the sender unit to this alloy block?
b) The above mentioned alloy block that carry's the sender unit is hollow through its middle and has a threaded bolt running through it that screws into the crank case (my damamged part) with the other end connecting to an oil pipe that feeds the righthand cam. Does anybody know the factory torque setting for this bolt where it screws into the block?
c) The above mentioned alloy block that carry's the sender unit is not a true "cube" One of the bottom corners has a flat on it. When you stand at the back of the car looking at the sender unit, should this flat be on the corner facing my feet or facing the front of the car?
Any help would be great as I'm currently living in a state of palpatations at the moment as if my re-assembly doesn't work, I'm looking at an engine out job to fix properly.
Rgds
Antony
Rgds
Antony
