Technical diagram
lali
Does anyone know where I can get a copy of a technical diagram of the outside of a 944, preferably with measurements or a scale.?
One of the tests in the Ultimate 944 Portfolio (this jobbie HERE has one.
I shall bring it in tomorrow and scan said object. Can email you a pdf if you like.
(It's from a test of an early lux vs excel and I was astounded to see the excel roofline is almost 10" lower than the 944 (!) )
Any use?
944 / 944 S
944 Turbo
Length
168.90 in. / 4290 mm
Width
68.31 in. / 1735 mm
68.31 in. / 1735 mm
Height
50.20 in. / 1275 mm
50.20 in. / 1275 mm
Wheel base
94.49 in. / 2400 mm
94.49 in. / 2400 mm
Wheel track, front
58.15 in. / 1477 mm
58.15 in. / 1477 mm
Wheel track, rear
57.13 in. / 1451 mm
57.13 in. / 1451 mm
Ground clearance*
4.72 in. / 120 mm
4.72 in. / 120 mm
Tuning circle (curb to curb)
31.17 ft. / 9.5 m
31.17 ft. / 9.5 m
Tuning circle (wall to wall)
33.80 ft./ 10.3 m
33.80 ft. / 10.3 m
Overhang angle, front*
14°
12,5°
Overhang angle, rear*
15°
15°
