andrew_churcher
Hi All,
Being new to aircooled 911's I have a question about the temp gauge in the car and the oil cooling fan operation etc.
Coming back from the Porsche and Polo last Sunday i got stuck in a traffic jam. It took over 35 mins to get on the move sufficient for the spolier to rise and get some air cooling the engine. While stuck in traffic I noticed that once the temp gauge hit 3/4 i expected it to fall once the air cooling fan kicked in. The gauge did stay at the 3/4 mark for quite a while but instead of falling it rose to about the 10oclock mark and i was seriously concerned about the temp at this pt. Fortunately i got onto the M40 and the car cooled to back under a 1/4 (first white line).
Anyway - I did a fair bit of reading and my understanding is that the cooling fan is suppposed to kick in and lower the oil temp back to a normal level (say half way or under). This didnt happen (plus it was a hot and humid day).
I did a check this Friday evening (outside air temp much cooler) and after a 25min drive i let the car idle for about 8 mins....the car hit 3/4 mark on the temp gauge and i heard and felt the oil fan kick in (felt under the right front fender for air flow) and this lowered the gauge temp down to halfway (as i thought it was supposed to but didnt in the preivious scenario).
So - it appears that thermostat opens (right fender was/is warm)....oil cooler fan kicks in when its supposed to...but when i needed it the most (stuck in traffic and no where to go basically to turn engine off)....it didnt seem to cool the car.
Anyway - if anyone has any advice for me....then that would be appreciated. I guess i want confidence that if stuck in traffic then the car will cool itself and not overheat. Is this to be expected in hot and humid conditions when stuck idle for 30-40mins in traffic?
Best Rgds,
Andrew
Best Rgds,
Andrew
