chriscoates81
I found this in the technicl articles about the light on my guage flashing. Im sure its either option 1 or 2 as its quite slow, how do i check to see if the compartment blower if faulty and if it is how much is a replacement and can i do it myself?
COOLANT WARNING LIGHT![. [FONT=verdana,geneva"] [FONT=verdana,geneva"]](/forum/styles/default/pcgb/space.gif)
(in the temperature gauge)![. [FONT=verdana,geneva"] [FONT=verdana,geneva"]](/forum/styles/default/pcgb/space.gif)
Four functions of the coolant warning light: ![. [FONT=verdana,geneva"] [FONT=verdana,geneva"]](/forum/styles/default/pcgb/space.gif)
1. Engine coolant level too low
"” light flashes slowly (0.5 Hz)
2. Engine compartment temperature too high
"” light flashes slowly (0.5 Hz) (engine compartment blower might be faulty)
3. Engine coolant temperature too high
"” light is lit; pointer on the right
4. Temperature sensor at water outlet faulty
"” light flashes rapidly (1 Hz); pointer on the right
Note
The temperature warning in point three is indicated if the conditions "engine coolant temperature too high" and "engine coolant level too low" are present simultaneously![. [FONT=verdana,geneva"] [FONT=verdana,geneva"]](/forum/styles/default/pcgb/space.gif)
(1Hz = 1 flash per second. 0.5Hz = 2 seconds per flash)
Note
