MikeH
Hi All
I've done a search but can't find what I'm looking for, so here goes...
I've got a 1977 Carrera 3.0, which has the same electronic heater control [
] as the SC - temp. sensor behind the mirror, and a numbered dial in the centre, to give the illusion of analogue control.
Surprisingly, in the 4 years I've owned the car, it's been fine, but now that the warm weather's here it's decided to stick full on, and the car's completely unusable. However, with the info I've already found, I can now bypass the electronic servo and use the old fasioned cable method. However, currently the 'automatic' red lever is in the fully up, full heat position.
I've read the other posts about checking the heater valves, and I'll do all that, but I don't think that's the problem. When I close the dial (position 0) behind the handbrake, I can hear a click from a microswitch, but the servo motor doesn't run (I used to hear a gentle whine from it). So, does anyone know what electrical currents / voltages / resistance I should be able to measure and where, to test if the central control unit is ok? I'm hoping someone will have a Bentley Manual (I'm looking to buy one, if you're selling!) which might list some tests for the control unit.
Thanks for any help
Thanks for any help
