What's best way to test a wastegate? I was thinking I needed something special. Then I discovered that a bicycle pump, which has a rubber washer to grip the inner tube value, fits nicely over the air feed on the top. Does that sound OK?
If I pump the pump, the valve is gradually pushed down. A couple of pumps and it moves a little and a couple more and it is significantly open (I wasn't sure how far to push it). The valve only closes when I remove the bike pump from the waste gate. It closes very rapidly.
Is that good enough? Or is there a more quantitative test required to test it is fit for purpose?
cheers,
Chris
87 220T.
cheers,
Chris
87 220T.
