I Broadly agree with replacing the control arm complete with new bushes,but they are unjustifiably expensive now £260 per side when only a couple of years ago they were £160 and that price rise was in one go& overnight, along with an awful lot of other general parts for all of the older vehicles,The price alignment as they called it, just made everything expensive.But what really hurts is that the new arms dont last anything like as long as the originals,I know an owner who had a new pair of arms just before the price increase and they were showing early signs of unbonding at under 2 years , it was not bad enough at the time to issue warranty replacements (although one opc said they were and the selling dealer said they were not) having examined them at three and a bit years old the unbonding has continued and is showing signs of becoming quite considerble now.I would not be happy with that kind of life expectancy for the money.
I dont think the increased harshness of the ride is easily detected with the solid replacement bushes and if you fit a set they will certainly outlast the versions porsche has on offer. Steve Mchale mentioned that the replacement bushes make the arm a bit stiff unlike the genuine rubber ones.This is true and an undesirable characteristic of them at inital fittment.But it will be interesting to see what they are like in a few years.I dont really buy into the weakening of the alloy arm itself theory a long as the old bushes are removed properly.
As an interesting note, if you have stiff suspension(m030) the Std bushes last much longer as they dont get the deflection they would on a std or mo33 car.This would hold true with aftermarket springs as long as you dont deviate too far from the factory ride height because if you do go too low(rs spec) or indeed too high, the front bush (which is the quickest deteriorating one) has a locating lug to position it on the subframe and that bush will be under twisting tension constantly if you go too high or low.This will overcome the bonding very quickly.There should be no tension on any of the rubber flexible suspension bushes anywhere on the car at rest.This is why when these components are removed or replaced they are always finally tightened on the bush end with the car in its running state (i.e on its wheels, suspension settled in by brieflly driving)If you want to run low you need to run rs control arms (and ideally rs front uprights/hubs/steering rack ball joint/rod ends so that the steering rack alignment is maintained)or remove and reposition the bush in the control arm to take the tension ouy of it(that is near impossible to do without damage to the bush) The replacement bushes have no such drawbacks from a ride height point of view,So should be considered at least.There are a number or makes around , one being the ones geoff everet developed and made by powerflex, there are some marketed by gert at carnewal (manufacturer unknown) and he is quite fussy about what he sells.and one other brand the name of which escapes me(english company i think) thay are all slightly different in their designs and gerts are the only ones to use the original steel center of the porsche bush,powerflex ones come with their own stainless steelware.They all seem to exhibt the undesirable stiffness when first fitted.(it wouldn't really factor much with a tonne and a half pressed down on top of them) But i would be happier if they were a little more compliant when installed.
not sure what i am saying about which way you all should go but just a few points about each option.
regards C
