Shane Hodges
I posted some time ago on how to get access to the heating / ventilation system as I had a very bad vibration at higher speeds. I think I've found what it was but now have another question!
It appears that whatever I went over with the left wheel went straight up into the radiator behind the left wheel - I understand this is the aircon radiator rather than the oil cooler radiator?
It basically stripped an awful lot of fins from the rad which obviuosly went in all directions ... and are now dropping back out from the bottom of the PU.
Am I OK to run with gaps in the rad? I see no fluid leaks, so the system appears to be intact.
Any comments would be much appreciated. Thanks.
