The Best Tyres for a 987 Boxster?
- Thread starter TomYates
Black80XSA
More expensive but last longer, very consistent in wet n dry and road noise pretty good.
Michelins seem to win lots of fans on 9x7 and 9x6 cars - Bridgestones might be another option but the reports are a little mixed.
I only got it a couple of weeks ago - wanted one for ages! I knew exactly the model I was after and took months to find one at the right price, but finally got it!! It's an 05, black with black leather with the bose system, PCM and sat nav and even the crested wheel centres. Just had another full service too. It's a 2.7 tip, which for me is the ideal model. The S would have been great, but just so much more to run and insure. It was difficult enough finding a sensible-ish quote for the 2.7 because of my age.
Welcome to the forum .I have a 06 2.7 Tip 24 K mls and run on 17" Conti Sport 3 find them ok I dont drive hard or do track days any more , it was Conti that was on the car from new just upgraded to the new Sport 3 about £500 a set inc There is a lot of debate on which is best
Brian
Black80XSA
I believe even 18s are Michelin Pilot Sport 2 model.
gammonnetti
If you are interested in the Bridgestone then the RE050A is the one for out and out performance where as the RE050 is designed for higher levels of comfort; it depends on exactly what you want from the tyre. The RE050 is a directional tyre and its main strength is to negate hydroplaning. The RE050A is an asymmetrical tyre that has half the tread given to water evacuation and traction with the other side focussing on the cornering and thus combining to give a very high performance tyre in all conditions. Bridgestone can supply you with a technical sheet if interested. Hope this helps.
__________________________
987 Atlas Grey
