morris944s2john
For your amumement the list of things wrong with my S2 and which ones I have so far attended to.
1. Engine overheating (I hope its just thermostat)
2. Leak from coolant elbow
3. Clonking worn balljoint in wishbone
4. Front right brake squeaks
5. Brake judder from high speed (possibly related to 3)
6. Clutch judders when hot (on the way out no doubt)
7. Vibration felt through gearstick at 3000+RPM (related to 6?)
8. Front alloys need re-furb
9. Steering has play due to worn intermediate shaft
10. Bad/sticky ISV (I think) causing idle fluctuation on 2nd or 3rd hot start
11. flexible brake hoses need renewing
12. Fuel pipe clamp missing
13. We're not having a 13!
14. Belts, rollers and tensioners due this year or next at latest.
15. Clunk from rear, possibly CV's need re-packing or replacing
16. Missing rear disc dust shields
17. Gearbox stiffer than it used to be (change oil)
18. Cracked front headlight lens
19. Rear numberplate light broken
20. rear screen heater wiring breaking up
21. internal fan only works on position 4
22. Drivers seat bolster need repair
23. Glove box lid lock is broken
24. Wiper intermittent interval adjuster fell out of slot
25. LED clock U/S
26. Rear wheelarches have some rust
27. Sills still have some surface rust
28. Some panels looking dull
29. cassette box lid broken
30. Carpet lifted off door card
31. Probably cams will need replacing in a few years
32. LHS wing has some rust at base
33. A few small dents here and there.
34. Exhaust cracked in front of Catalyst (de-cat, or weld up).
35. Rear hatch rarely opens via key (footwell switch ok).
36. Handbrake at end of travel (stretched cables)
37. Front spoiler has some damage (needs repainting)
38. Rear seat does not always hold seat in upright position.
39. Driving light cover cracked.
40.[
][:-][8|][8|][8|][8|]
Looking on the bright side jobs done:-
1. Refurb front callipers, sorted plate lift
2. plate lift sorted on rear callipers
3. Replaced leaking radiator
4. Cured slow cranking (new big battery, recon starter, clean earth leads)
5. Replaced stolen badge
6. Replaced most of the hard brake pipes
7. Replaced front ARB bushes
8. Cut out rust and welded sills- finished in stone chip and guards red
9. Repair and painted drivers side front wing
10. Cleaned off surface rust and painted badge panel
11. " " " " " headlight covers
12.
I'm going to tackle most of the jobs 1-39 myself, MOT/ reliabillity items first,
otherwise the car would cost so much to sort it would be more viable to break it.
I would also say my car is currently not a good example of one to buy!!!
Jobs will be done in order of safety, MOT and those needed to keep the car reliable and running. Some parts obtained, some on order.
25. LED clock U/S
40.[
12.
