The ultimate 964 RSR - Brand new!
Akshually, given the cost of 'used' ones, it seems to be good value!![:)]
But what a record of an original vehicle.
It even looks as if it has the original packing at delivery to the team ?
And, did you notice that the door handle trim is falling off from new ?
Like they all do unless they are glued in place ..
Looks great doesn't it..... nearly as clean as mine.[8D]
The door handle caps aren't falling off. The factory had to remove it to fit one end of the Red door pull strap behind the door handle front bolt. You have to do this on the cars with the cross bars in the door or the door pull gets crushed behind the door bars making it vary hard to get out. With the door strap fitted here it's impossible to refit the door handle cap. Normal RS's have both ends of the strap connected to the release mechanism behind the door card.
ORIGINAL: RSR
Thanks Paul, Happily learning !! '[;)]'
