Thermostat!
- Thread starter Guest
Provided that you have put it all back in as it should be, with the correct spacer washers, mine had 2.
Get the circlip, and a file, and gently file down the edges to make it slightly thinner. By slightly i mean enough to take the black off and reveal shiny metal, this was enough for me to get it back in the groove.
I think its just a case of it being in there so tight, that it wont go back in unless you can clean the groove out a bit, which is soooo hard with the pump in the car, that filing the circlip is easier.
