Kevin Welch
Hi there, Looks good to me. definitely worth a good poke around.
So after a lot of classifieds searching I've ended up making a purchase of the car in the link above. It's a nice car overall, 10 OPC stamps (Guildford and mostly Bournemouth) since new appearing nice and straight. The paint is very good with the odd scratch here and there but nothing that can't be polished out.easily. Everything works as expected and the car whilst not the first choice of Seal Grey looked very nice in the sunshine, the alloys certainly lifting it. It's spec if high other than not having Sat Nav and reversing sensors which don't worry me. It has the nice memory sports seats, litronic lights, heated seats,Bose, dipping mirrors etc. Only three owners, the last keeping it for 9 so a good ownership. The car ran very well, no oil leaks and just the usual advisory on minor brake disk pitting but nothing bad visually and it broke well. It has new pads but are not bedded in totally. The rads appeared to be good and the AC was working well with the roof up. Faults - A "rubbing" sound coming from the N/S/R area, it's either the brake pad rubbing or a possible wheel bearing issue. It was there the whole time once moving, not just on making turns etc. The seller is getting it fixed so hopefully not a problem. Other than that, it felt solid and drove excellently. I should get it this coming week and so will get some better pics once I have it home. Couple of questions. The clutch on the all the Boxsters I've driven generally feel pretty heavy, normal I'm assuming? No slippage etc. drive a PDK so forgotten what a clutch feels like [ORIGINAL: Clewsey Ok, found another example that looks good on paper. Its higher mileage but I'm not too worried. As long as it's been looked after. Whilst I'd prefer the original wheels, these don't look bad and lift it especially with the car exterior colour. http://www.ianfoxautomobiles.co.uk/used-car-porsche-boxster-convertible-128 Thoughts? Cheers
