golfprorich
When I had my inlet manifold off for cleaning the ICV, I removed the air oil seperator to check the seals. There was something rattling inside which turned out to be a baffle. However on removing the top I managed to break a couple of lugs. I sealed it best I could but on doing a smoke machine test to chech for vacuum leaks its was clear that the air oil seperator is leaking at the top.
My question is, are they the same across the range? I have a 944S
And if someone has one for sale please let me know [
