Chaps,
A bit of a Monday morning musing. (Maybe I'm bored, which is a bit naughty as I've just told Mr Empson off for a very similar admission!)
My S2 is standard. When I start it in the morning, the engine is cold and the oil pressure gauge shows 5 bar (I think it would show more if it could.)
It being a 944, it heats up very quickly. 5 minutes or so of gentle driving later and the temperature gauge is around the first mark, the usual 'running' temperature, and stable. And the oil pressure is around the 4-bar mark. Slightly over, if anything. So, normal running temperature and 4 bar of oil pressure.
If I then drive it as it was designed to be driven, the temperature gauge will rise ever so slightly. Slow down a little, some more sedate pootling, and it will be back to normal. But the oil pressure gauge will have dropped to 3 bar ... less, if it's a hot day. I think I've seen sub-2 bar on a really hot day in a long traffic jam (manual says over 0.5 bar is OK.) BUT the temperature gauge was still around the 'normal' point. The oil pressure will rise again, with some more gentle driving, but will never get back above about 3.5 bar unless it is switched off and left to cool.
So, what's happening? There isn't a direct relationship between the temperature gauge reading and the oil pressure gauge reading. 'Normal' temperature can equate to anything between about 1.7 bar and 4.1 bar on the pressure gauge.
I know that the temperature gauge is showing water (not oil) temperature, which probably goes some way to explaining this, but I have two questions:
1. What is the relationship between water temperature and oil temperature? Does the water temperature lead the oil temperature? Always? Or isn't it this simple?
2. What other factors affect the oil pressure at a given revs? (Assuming it's the same car, at the same time - i.e. engine wear hasn't changed.)
