Hi guys,
I am new to PCGB so hopefully I have done this right, I only joined the beginning of the year as I intend on tracking my 2005 Boxster S 987.1 this year. I was kind of hoping that my first post would be in relation to this, however 2 weekends back I took it off axle stands after replacing all the coolant pipes at the front end and servicing it over the winter and went for a test drive, unfortunately as soon as I left my drive the throttle became unresponsive when I lifted my foot and reapplied the throttle the car came back to life it then happened several more times during a 2 mile test drive.
Last year a few months before I put the car away for winter I had experienced similar symptoms, but back then it seemed to happen only after the brakes had been used, the next time you accelerated it would initially accelerate then the throttle would go dead and you would maintain the speed you were at, sometimes it would spring back into life on its own if you kept your foot where it was or if you released the accelerator then reapplied it it would then be back to normal the other way to reset it was to dip the clutch, it was intermittent but was happening enough for me to identify these traits. After some research I decided to change the brake micro-switch and this appeared to fix the issue. This time the symptoms seem different I don't believe it is related to the brake pedal and when it does happen the car slows down like it has lost all power but if you dip the clutch the engine is still running, the only thing that seems the same is if you take your foot off the accelerator it returns to normal, unfortunately I have not done more than 6 miles in it around our village at 30/40 mph since this has happened so it is a little difficult to say if this is the full symptoms, the only other thing I could potentially add is it has only happened in 1st and 2nd at slow maneuvering speeds.
I decided to get a diagnostic machine as I was sick of trying to guess what issues I have, I ordered a Thinkdiag+, I read the fault codes and there were not any related to the DME or PSM systems. Initially with it seeming to happen at slow speeds and turning I thought I would look at the PSM, I monitored Car speed, all 4 speed sensors, Steering angle sensor, brake light switch and the PSM Active signal. When the fault happens all the speeds match nothing wacky seems to happen with the SAS deg, the brake light switch is not active and PSM stays inactive and the dash traction control light is not illuminating, so I don't believe its PSM related.
I then decided to monitor the throttle response when stationary, i get the extremely similar results as Mac who used a durametric on his own car when it was serviceable granted it was for a 996 but I am hoping it is close enough, Mac got the following:
Hi plugged in the durametric today, no fault codes logged
the first number is with ignition on and foot off the accelerator, the second with foot to the floor
off / full
pedal value 0% / 99.99%
pedal encoder potentiometer 1 0.76 volts / 3.3volts
pedal encoder potentiometer 2 0.38volts / 1.65volts
specific throttle plate angle 4.2% / 99.99%
actual throttle angle 4.2% / 99.9%
throttle position sensor 1 0.78volts / 4.35volts
throttle position sensor 2 4.25volts / 0.67volts
throttle plate angle potentiometer 1 6.2% / 99.6%
throttle plate angle potentiometer 2 5.8% / 99.6%
Thanks to MAC996t for posting this on 911uk.com
I decided to take the car for another test drive and monitor these values, I have attached a screen shot of the graph. The fault occurs at time stamps 30, 60, 105. I am hoping the picture quality is good enough, on my phone the screen shot is really clear however looking at it on this laptop it is not clear. Anyway at those time stamps you will see the dark blue line (Data Pedal Value) goes flat line at around 4.5%, however the red and yellow line (Data Pedal encoder potentiometers 1 & 2) keep on rising, on the 2nd and 3rd time I floored the pedal and then lifted it slightly and pushed it back to the floor to see if it kicked back into life which it didn't and hence why they look like an 'M', and when all this is happening the turquoise line (Data Nominal throttle plate angle) returns to almost closed.
I am not entirely sure how the Data Pedal Value is calculated, as far as I am aware there are only 2 potentiometers in the pedal which would correlate with the 6 pins on the sensor of the pedal, I would assume these are the encoder potentiometer values. Any way I believe as this Data Pedal value drops to 4% and the other values are still rising the computer doesn't like it and closes the throttle plate. I did find on the internet someone with the old 986 cable pedal rather than drive by wire, have symptoms where the potentiometers were reading fine but the Pedal Data Value range was only 0-30% all of the time, he replaced the potentiometer sensor and it fixed the issue. My thinking is that on the 987 drive by wire system the Accelerator Pedal is the same component so will probably fix the issue.
Anyway I am hoping that someone on here is far more in the know how the system works and if there is a possibility another system like the PSM is causing this value to drop to 4%.
One final thing has anyone taken the Accelerator Pedal sensor apart before, I have had a look and it looks feasible or better still knows the pin out so I can try and do a resistance check will operating it?
Sorry for the really long post but hopefully I have managed to put enough detail in for someone to help.
Many Thanks Paul
off / full
Many Thanks Paul
