ive just purchased a boxster s and after it has been parked in the garage for a few days i get a spot of oil on the floor. ive been told by opc that it requires a ring main oil seal and it is a common problem has anyone else had this problem because opc have quoted £900.00 for this job but they told me it wont cause a gearbox malfunction if not treated, the only thing it may cause is the clutch to wear out.
I also have a problem with 3rd gear when the car is cold, it is a little bit tight to select for the 1st 5 mins of driving but then its ok. anyone eles had this problem or is it just my bad luck.
the car has only done 32000 miles and has a full dealer history with a major £782.00 service done in november 2005 and the only advice on the invoice is brake discs starting to wear.
