Time to go, old girl
Veerzigzag
I will have to sell my '89 2.7 at some stage soon as we are moving to France, whereupon I shall doubtless reappear with a LHD French-registered version.
At least the rear wiper on a LHD will possibly be of some use!
Before launching myself into the collection of scammers, time-wasters and dodgy traders than make up eBay (present company excepted) I thought a quick listing here with a good price might be sensible.
There are some pics here.
Pale gold "metallic linen" body colour, with standard Recaro velour seats in dark brown with cream pinstripes. Seats / interior very good but with a couple of small cracks on the top of the dash.
Brand new high-tech indoor / outdoor tailored cover.
Two sets of wheels: the original (not kerbed or scratched) 15" teledials and a set of Porsche Cup 1's, I acquired the latter ones from a racing team (no kerbing but quite a few layers of paint!), had them refurbished/powder-coated and fitted with Conti Sports and Richbrook titanium valves a couple of thousand miles ago.
New clutch+sensors+slave cylinder and have spent lots of time keeping the detail stuff working, like rear hatch release system overhaul and ditto for the sun-roof. New rear discs / pads / shoes. Lots of fasteners replaced with stainless ones.
Manifold-back stainless exhaust system (the car has the factory decat option) which is, er, rather raucous but makes the engine noticeably freer at the top end.
Compression perfect when checked, as were the coolant system and cap pressure-tests.
Everything works, apart from the rear wiper (removed, and a posh racing bung fitted) and the headlamp washers (removed, as they don't make any difference to dirty lights but they do dump half a pint of soapy water onto the mechanisms).
Belts are about halfway through their life and last time round the seals were changed as well.
Sills have not been replaced but are sprayed internally with Dynax and I don't think this 944 has been left out in the rain very much.
Paintwork has clearly been redone and I had an expensive respray on the front end to remove chips and marks - a perfectly matched job.
It's not a perfect car but then the price isn't "perfect" either. But it does look good, sound good, run well and it has a good provenance.
MoT until 23 July, and tax to end March, mileage 165k, of which about 10k per annum for the 2 years I have owned it.
All history docs in a very full proper PCGB binder; the historic mileages all look OK.
Thinking of offering here at £2.5k with both sets of wheels or straight £2k with just the original tele-dials.
Location close to the top end of the M11.
Click on the photo "Get Links" then select the "Direct" link and put the usual [img ] [/img ] without spaces either side :)
here is one, when viewing the pic on PB click [direct] to the right of the image paste it between the image boxes here (edit this post to see) edited to add Daryl beat me to it so deleted most!
Hi. Tried to send you a private message yesterday. Am interested. Can you text me on 07581793228? Thanks, Soli
Mike your car looks good mate. Good luck with your sale,I can't see that car being difficult to sell as there's not so many good solid cars left now.
Hi Soli, will do.
But bear in mind (looking at your other postings) that it is not a £10k time-warp immaculate concours monster-power-turbo....
As per postings above, Alexsmith has first refusal....
One last go on the forum, then (oh dear) off to eBay we go.....PM me if interested (note to Alex Smith - your PM box is full so please call me asap if still interested)
My 1987 944 2.7, linen metallic (pale gold), mocha pinstripe seats, about 165k miles, tax to end Sept, MoT to 23 July (no advisories last time), 2 sets wheels, scrubs up very well, drive away for £2k (will be more on eBay)
Located between Cambridge and Huntingdon, happy to collect from either station for train-in, drive back home.
Notes on work done:
Re-sealed the spotlights, replaced fasteners where possible with stainless / allen headed
Removed headlamp washers, sealed pump with silicone-rubber cap
New front Porsche badge
New number plates (GB style with no extra text clutter) and Porsche number plate holders
New front ARB links and bushes
Iridium longlife spark plugs "" compression checked OK
Replaced brake fluid
Replaced coolant "" pressure test on system OK, pressure test on cap OK
K&N reusable (washable) air filter
Air filter box fasteners replaced with stainless ones
New stainless exhaust "" manifold back
Oil change autumn 2013; Castrol Magnatec 10W40, K&N oil filter
Removed wheel arch guards and cleaned inside wings "" sprayed with Dynax
Cleaned and painted brake callipers, refitted pads using copper grease
New black alloy wheel nuts
Sills sprayed internally from both ends with Dynax using 1 metre extension wand - internals look OK in photos
New rear discs with new pads and new handbrake shoes
Sunroof new seal, mechanism stripped / cleaned / greased, new gear wheels, adjusted motor clutch
New rear speakers (6.5" sub-woofers), radio wiring tidied
Door cards removed and window mechanisms cleaned / greased (but windows still slow, 944-style!)
Luggage pull-out cover refurbished
Rear carpet studs replaced with stainless poppers and upgraded plastic studs
Gearbox oil changed at last MoT.
New clutch plate (all-metal), with new cover, release bearing and slave cylinder
Replaced the TDC and RPM sensors
Rear hatch seal replaced
Rear hatch new release cable and new rod end-caps as required
Removed rear wiper and fitted a Promax plug in the glass (original parts go with the car)
Battery securing nut replaced with stainless one, terminal covers fitted
Front-end "stone chip removal" respray
New windscreen
New indoor + outdoor tailored cover
Comes complete with:
Sunroof sleeve
Spare DME relay
Torque wrench with correct (long) 19mm socket
Good quality tyre pump
New Porsche original locking wheel nuts
Porsche genuine 16" Cup 1 wheels perfect cond, powder coated, Porsche centre caps, Richbrook titanium valves
Cup 1's have Continental N1 Sport tyres, few hundred miles wear only
Porsche original 15" Teledial wheels in good order with no marks or kerbing, Pirelli 6000 tyres with some life left in them
Porsche official Certificate of Authentication
PCGB written valuation (£6,000)
Documents kept in new PCGB Vehicle Documents ring-binder
