timing belt on 924s
- Thread starter usermjg
pauljmcnulty
ORIGINAL: usermjg
Hi Guys
Just a quick question, if the timing belt goes while the engine is running on a 924S is it fatal, will the engine need a top end rebuild?
Hi Mark,
Short answer is yes, as it's the same engine as the 944.
Is this question because it's happened? You might be lucky, but usually bent valves at least. Or, if you're hoping not to change the belt then it's not worth the risk. If it's a car you're looking to buy then get it checked out first.
DON'T RISK IT.
pauljmcnulty
As I said, he might well have got lucky. I've heard of nothing more needed than a few valves, although the cost of this, plus obviously the belts and probably the other bits like water pump, oil seals etc if it's not been done for years, will be hard to swallow as the cars are worth so little. Engines are pretty reasonable, as cars get broken so readily now, but with labour, ancillaries, other things like a new clutch whilst you're in there and vat, it's still a fair amount.
Once you know the extent of the damage, it's a case of weighing up the condition of the rest of the car. If it's in poor condition all round, needing other money spent on it, then posibly any money would be wasted. If, however, it's a very good example then I'd be wanting to keep it on the road as so few good ones are left.
I might get it towed back home and work on her as a long term project.
Thanks for the feedback, very much appreciated
924nutter
