Timing Belt
- Thread starter JaseGT4
chrisg
barnes89
Just bought a 1985 944 Lux ( my dream car ) about 2 months ago and the owner hasn't changed the timing belt in the last 10 years! It had been off the road and garaged for 7 years. I was wondering if it is vital to use the belt tensioning tool or if you can do the job without it? Any information or experience you could share in changing the belt would be great. Whenever i drive it I am worrying about the belt potentially snapping and causing irreparable engine damage :S
George Elliott
blade7
Well-known member
[] The cambelt can be removed/replaced without removing the pulleys, the crank lock has to be used if the waterpump or front seals are being replaced and that's because the pulley has to come off to remove the rear belt cover.ORIGINAL: George Elliott you want to do it properly and re-torque correctly without damaging pulleys with chain locks or cutting the knuckles off yourself,
pauljmcnulty
barnes89
