Timing belts, rollers are water pump
charles.y
Looking to replace the belts and rollers soon.
What is the usual price for the job? How much for replacing the water pump and is it recommended every other belts change for the S2?
Depending where you go most independants are charging between £250 - £350 for a belt change at the moment.
Doing all the rollers at the same time will be about £150 extra
The water pump is hardly any extra labour whilst the belts are off but the price of the part varies wildly (currently £146 from Bert, £276 from Eurocarparts)
Charles,
I've just had a major service and my belts done. I asked my indie to fully inspect everything and they recommended not to replace the rollers and water pump as they are working perfectly / look fine.
The major service, MOT, all belts and extra labour for checking the pump and other things (that's another story...) came to just under £700 all in.
Chris.
Waterpump from ECP £125inc, can be lot more labour also if bolts shear which they often do (rad then needs to be removed + drilling etc). Bear in mind front crank pulley has to be removed also which can often seize.
Rich
Chris, Did you Use Zentrum?
I heard they are really Good ...
I've booked my Car there For a Cam Belt ETC change Tomorrow...
ORIGINAL: Nouveau
Nouveau, Yes I use Zentrum.......and they will be seeing me again soon for even more work.
Chris.
the 2.7 and the S2 uses a completly different pump to the 2.5 models (including turbo and S)
Porsche had a recent price change
my cost for Genuine 2.5 £130.00 echange S2 £146.00 exchange all plus vat, while stocks last
