Tip on a Track day
- Thread starter andymac
You can't over-rev the engine by shifting down too early either.
In theory they should be slightly slower, but driver ability is a much bigger deciding factor.
The only bit I am not sure about is what happens if you spin.
In a manual you need to dip the clutch to avoid running the engine backwards (something that is not covered under the warranty, btw).
I guess the tiptronic looks after this for you, since there is no quick way to put it into neutral.
I don't think they get upgraded for that.
Manuals use a derivative of the 993GT2 box, so I reckon it'll take a lot more. However, the more you do, the faster it'll wear.
Tiptronic uses a Merc box I believe. I don't know what the rating on that is. (Some Merc boxes will go up to 1000Nm).
It is not the power but the torque that will break it.
