my boxster seems to have a fault. the problem seems to be that when i take off from cold the indicator shows it to be in first gear ,but when i stop at lights ect, the indicator shows that i am in second.Icount the gears up and it appears to be missing first gear, but if i switch to manual it works fine.Is this expensive to put right?
tip tronic fault
- Thread starter daws
They all do that - there's nothing wrong. It will start from cold in first, but when you stop, it only changes down to second. The first-second "gearchange" you are counting (at 2500rpm?) is actually the torque converter lockup clutch locking. If you want to take off in first after a stop, click it down on the tip switches.
