hi all, just to let anyone interested know that my recent atf fluid and filter change has now been carried out and was pretty much straight forward. only problem I had was with 9 of the sump bolts rounding on trying to remove. as luck would have it, my local indie PCT COVENTRY who I cannot speak highly enough of, came to the rescue with the last 9 bolts that they had in stock. one point worth mentioning was that on filling up whilst at 70 degrees it took 5 1/2- 6 ltrs to get to required level. I suspect that the extra amount of fluid over Richard hamiltons estimate was due to the fact that the valveblock was dripping constantly whilst I had the sump pan off for for several hours whilst cleaning/ sanding/spraying the outside before refitting. I hope this helps anyone who intends to carry out this procedure themselves.
tiptronic fluid change
- Thread starter raybonnar
thirteeneast
Hi Ray,
Did you make up something yourself for re -fill?.
thirteeneast
thirteeneast
http://www.renntech.org/forums/tutorials/article/68-tiptronic-transmission-service/
Worth registering so you can see the pictures.
