My 1998 C2 went to main dealer for a change of the automatic transmission fluid and filter. On collecting it I noticed the selector was flashing between "4" and "D". It was immediately taken back into the workshop and reset. Tiptronic then worked perfectly for the next 200 miles until it then did the same and would only change between 1 - 4 gears and not manually, also bit rough particularly putting in reverse. I understand this is standard selector flashing when something wrong with the transmission and it goes into "limp home " mode.
Went back to dealer today and they have diagnosed something going wrong with the multi switch/sensor on gearbox and needs replacing. I can accept that its old (114k miles) and things go wrong but seems a bit coincidental with the ATF change - but they wouldn't have touched the sensor doing the fluid/filter change. Does anyone have any thoughts on it before the work is done? Thanks.
