Hi,
We replaced the existing tip box last week. The previous tip box was not giving any errors either in DME or TCU. The previous box had a minor leak on the input shaft seal/oil pump and is currently being fixed.
However since we had a spare, we stuck that in, but as soon as we did this, and turned the ignition, we got a p0702 error in both dme and tcu. Effectively it is in limp mode.
The code points to electrical issue, mainly down the route of fault TCU. But it was working fine before. Since the engine was out, the battery was disconnected for a couple of weeks. The battery is fine.
When you clear the code, it just comes straight back.
If it is the TCU, then does anyone know anyway other than through OPC to recode?
The other issue is that if I need a new TCU, then I also need to send that over to Germany to get the tq limits increased. The tiptronic box is uprated by a company called MKB to 1300nm tq.
It just seems strange that swopping the gearbox over, we now get this message. The new gearbox was effectively brand new and had previously only 500 miles on it.
It just seems like the TCU is not taking to the DME.
