TOO LOUD ????
Yes, its too loud for pretty much anything. Avoid Gpipe and cup pipe together. Either one of the 2 and a decat,
I run with no cat and g pipe but still have the rear box sounds ok inside and out, i don't know if it would be to loud for track days! Berny.
All together would easily fail a static or drive-by noise tests I would have thought. Wouldn't have thought you'd end up with any much less as 103dB, if not more. I was so borderline with just a G and de-cat when I played around with a 102mm tail pipe with a resulting 101dB... You'll hate long journeys too after half an hour of in-car resonance [:D]
Decat and cup pipe will be automatic send home at nearly all UK trackdays. My car is about 105.5 with that combo. Not worth the hassle. If road only do what you like, but on long journeys, I wear ear plugs with decat and cup pipe, to give an idea. I guess a C2/4 has a bit more sound deadening which may make a difference.
