Too many owners ??
- Thread starter Diesel130
You just need to check who and why. It could be a good thing, particularly if it has been through an OPC or reputable dealer each time, as they should have properly prepared it for each owner.
As suggested, get it checked, ideally add the warranty, and try to make sure you get all the old invoices, handbooks, keys, tools etc (these sometimes go missing with multi-owner cars).
Watty
Again, don't worry too much about number of owners... I did with the first one I bought and the dealer showed me the log books of several others - average length of ownership seems to be 12 -18 months for the first 5 years or so! If I could afford a new one, I'd probably change it every year too [
ORIGINAL: Diesel130
Thanks. How many keys should there be Are the tools just the usual Jack and a screwdriver or are Porsche more generous in their toolkit ?
You should get at least two keys. If there is only one, make sure the dealer gets you another. A replacement remote key will cost over £120 including programming. Even a 'service' key is £50+.
You get quite a reasonable tool kit. Jack, wheelbrace, screwdriver, a couple of spanners, a special tool to remove the headlights, and a large plasic bag to use to wrap up a punctured tyre. (It won't fit in the luggage compartment, and you have to put it inside the car). On a C2 it is in a tool roll behind the spacesaver spare wheel. As Ian says, with a C4 you should get a tyre pump.
Rodney - if your spare is fully inflated, can you actually get it out?
Just checked it....actually it's probably not inflated........but I couldn't manage to get it out anyway! I would rather walk home, than have that heap of junk at the corner of my car with people laughing at me anyway! [
Diesel130
Yikes, so if you're on holiday with the car stuffed full of things, your stuffed.It won't fit in the luggage compartment, and you have to put it inside the car
ORIGINAL: Diesel130
That's right. Think yourself lucky if you get a spare. Spend £125000 on a GT2, and all you get is a can of foam to inflate and seal the tyre. Yea, right, that's going to work on a cold rainy night in the middle of nowhere.
