Top end Re-build
- Thread starter Guest
ClubSport 911
There is no one answer, but having just completed an exercise with a few large specialists to get an answer to the same question, have the following advise...
Mileage - no answer...can be from 15,000 to 100,000+...depends how driven
Parts - Rings, Valve guide oil seals, valve guides (perhaps) cam chain, tensioners...lots; of gaskets... Clips, pins, misc bearings... loads of oil,.... time to re-lap valves
Cost - £2500+ vat
I' ve got it all down on paper somewhere so mail me direct, and I' ll give you the details
Rgds
STEVE
I monitored oil usage and had it " dyno' d" on a rolling road to see if the engine was " tired" . In the end at 198bhp and 500miles to the litre of oil, I thought it better to have a top-end done before anything failed catestrophically! £2500 now is better than £4000 later!
Lloyd
and electronic fuel injection possibly helping out there to provide less stress to the engine...Move onto the 964 and it would appear a step was made backwards with reliability and servicing costs.
From what info I have been able to glean, most 3.2 engines would be considered for top end rebuild at around 100-110,000 miles, but if your lucky, can go on for a lot longer.
My own car is still original at 112,000 miles, although I haven' t had it dyno' d (yet)..but was in the shop for a minor running problem recently, whereby the cylinders were tested
and all is well with the compressions, and the seals of the valves/ports...
So if I' m real lucky, as I have no oil leaks (in 4 years have not had to top up between annual service)...I may have a couple of years or so left prior to major overhaul.
By the way, most independents/engine builders say the bottom end is generally good for 250,000 miles.
Happy motoring....
p.s. have just 1. touched wood, 2.rubbed lucky rabbits foot,3. on my way out to look for 4 leaf clover........
I am reluctant to have a top end rebuild because nothing appears wrong. Should I wait for a problem? The engine could go on for another 20,000 miles or so?
