mcgc0
Hi,
I have a '89 engine that I believe might require a top-end rebuild. Naturally, since '89 Porsche made a few essential changes in combating or curing known problems (generally associated with the often mentioned oil leaks). I have below a list of essential additions/upgrades collected from various readings and articles that should be included with a top-end rebuild (some may be obvious and part of a rebuild anyway?). Anyone aware of any other obvious additions/upgrades that I may have missed out? Also, I've made a secondary list of (performance?) improvements that would be nice-to-haves as part of any re-build. Any suggestions there too?
Essential:
- Distributor vent pipe kit
- Replacement distributor drive belt
- '91> cylinder heads and barrels (with the O ring seal head/barrel interface)
- Viton (green replacing black) O ring seals between barrels and crankcase
- Mandatory new valve guides
- Rocker shaft RS type seals?
- Steel (993 Turbo) barrel/head retaining studs?
Upgrades (optional):
- Post-'91 plastic air intakes (replacing alloy version)
- Single-flap throttle body
- Hot-film mass airflow sensor (replacing flap-type airflow meter)
- Performance chip (DIY)
- K&N/PowerFlow induction ((DIY)
Please correct or advise if any of the options above are incorrect, any other useful information also welcome.
Thanks..
Essential:
Thanks..
Thanks Steve and Ian. Suggestions and advice taken on board.
