The time may well have come for me to bite the bullet and get the top-end rebuilt. A cylinder leak test a few months ago showed between 4% and 8% on all cylinders, so absolutely no problems in that department. However the engine has started to blow an increasingly noticeable amount of smoke and use more oil (although probably still within the factory tollerance of 1 litre per 1000 miles) which would suggest to me that there is an increasing amount of valve-guide wear. Perhaps it's my imagination but the engine doesn't seem quite as perky as it once was either. With mileage at almost 100K it all seems to be pointing towards one thing (although as we know mileage in itself is no defining factor). I've done quite a lot of track work over the last year which I guess has merely accelerated the problem. The situation is clearly not dire but my usual specialist has been telling me for the last 18 months that a rebuild was on the horizon, so any other suggestions for other things to explore before taking the plunge ?
Assuming it does need a rebuild the price for the work seems to vary enormously. I neither have the time, knowledge, nor inclination to undertake the work myself so what experience of specialists does anyone have for this job ?
In addition what other jobs / upgrades are worth having done at the same time ? Typically I had the clutch done no more than 10k miles ago so am slightly reluctant to have it done again, although it would probably make sense to. I am toying with the idea of putting in an RS flywheel, however that may just make it difficult to use round town - any experiences ? Also thinking of rebuilding with 964 profile cams. I am reluctant to go for a 3.4 or 3.6l upgrade due to the expense involved but the cams might just give an extra bit of grunt for a more acceptable cost ????
All views / ideas / estimates of costs etc. welcomed !
Thanks in advance,
Jamie
Thanks in advance,
Jamie
