Top end rebuild
- Thread starter Nick
What actually is Nicasil
Well, and here I stand to be corrected, but I believe it to be an alloy of Nickel and Silica.
I know that silica is not a metal, so can' t be part of an alloy, but the end result is a very hard bore surface coating.
As to when it should wear out, I don' t think it does, unless damaged.
Other types of cylinder barrels on earlier engines are Alusil (no nickel content but same surface treatment) & Byral.....steel sleeve with alloy fins.
As Nickasil is so hard there probably is no good guide to long term life yet ........any of you engine re-builders out there know anything more? Rings wear due to them being softer than the bore and generally have a flat opposite to the spark plug.....a good reason to have twin spark plugs on later engines.
At 100,000 miles my rings were worn but still serviceable.....just slight smoke on start-up and output 183BHP against 190BHP stock (2.4S) what caused me to do top-end overhaul was valve guides wearing out.....the' re made of a high copper content alloy so pretty soft.....this is the achilles heel of this engine design.......anyone know why Porsche put these into an engine that appears to be otherwise good for 100K > 200K? [8|]
and Vat......undertaken by specialists not main dealer.
I have 112,000 on the clock now and still original, healthy enough although I havent had it dyno' d....crossing fingures, touching wood etc..but am starting a ' rebuild my engine fund' for the future.....not as much maybe as a new church roof but maybe I should take a stall at the PCGB autojumble and sell cakes to help raise the dosh[
£4-5k is about right but before you spend get a second opinion to see if it's really required, depending on how much mileage you put on ypur car, it may go for another 2-4 years before the top end needs rebuilding that should provide ample time to save
Had my SC done about 3 years ago at Carrera Engineering (01992 892333) at reasonable cost might be worth contacting Tony and get an alternative quote, had all my head studs replaced, new rings, oil pipes, tensioners, valve guides done etc replaced did a first class job[
carrerageorge
rings & valve guides, it was using 1 litre of oil to 400 hundred miles max
despite have a AFN service history every 6k.
No blue smoke at all from exhaust at any speed puffing up through
the oil tank.
Think mid 80s 3.2s had a ring problem as many seemed to have had the rings and valve giudes done.
Richard Dawson
That figure seems steep; I can't imagine Mike Bainbridge (who is one of the best) charging that much.
My car has 964 cams/ssis/ M and K back box putting out 270 bhp on Wayne Scofields rollers (on which my 993 RS gave 300bhp before he started work) and didn't cost much more all in !
I'd shop around.
Pete917
ORIGINAL: Richard Dawson
I have a 3.0 SC with a 3.2 engine.
I'd shop around.
Shopping around is very important. You'll also learn alot about potential engine builders reputation along the way.
