Top Up oil Mobil 1 spec 997
- Thread starter jpbecker
frankgosling
I have just asked the same question. I had a chat with a man called Guy at Opie Oils on tel 01209.215164. he said porsche used a few oils but Mobil 1 0w.40 full synthetic was one of the oils recommended by Porsche and it was perfectly acceptable to top up in my C4s even if it was not the same as the present oil.
He is probably worth a ring if you like me need reassurance.
Hope this helps Frank G
Andy
ORIGINAL: jpbecker
. . .I was surprised how quickly one bar on the oil gauge dropped . . . .
I confess to being somewhat OC when it comes to monitoring fuel/oil consumption.
Each bar on the oil level gauge is equivalent to 0.4 litre which means that the gauge indicates to the nearest 0.4 litre. So one bar down might only represent a little over 0.2 litre consumed, it's advisable not to overfill so don't add more than 0.2 litre at this reading. I make a note of the mileage when the gauge drops one bar and then when the gauge drops a second bar I know approximately 0.4 litre has been used so I can compute the mpl. With the gauge down two bars I then top up with 0.6 litre.
BTW Porsche say that better than 1000km/litre is within specification[].
