9M run this "fast road" set-up on Colin's 3.2. It's just turbo t-bars and leave the front alone. The turbo t-bars are only 1mm bigger but the spring rate is the third power of the diameter so its a big enough change to notice. I personally think the cheaper way to get to a similar place is to put on a 22mm rear anti roll bar. It does much the same thing in so far as it dials a little understeer out and makes the rear work a fraction harder. If you want to replace spring plate bushes then you might as well do torsion bars though.
As you probably know, I have 22/29s and ran them with Bilstein HDs for a good year or so. It very livable in terms of ride handling. I am now on custom valved race Bilsteins and the difference is massive. The ride is seriously hard and you steer around bumps, manhole covers and potholes. This is the right shock valving for the spring rates and should be killer on the track but its antisocial in its harshness - though monoball strut mounts do not help either. So, the message is, that if you compromise the track performance and run soft shocks it's OK for daily use but if you do it properly its a real step towards track toy only. I think that the US guys running 23/33s etc who say the ride is "just fine" must have much better roads than us or run softer than ideal shocks.
Best advice is ask yourself what you want the car to eventually be - track toy, fast road etc - and do it once and right with that goal in mind.
