Hi,
Recently had a bit of a problem, getting a sudden power steering fluid leak during a drive and would welcome some advice.
It was leaking heavily as I parked but the reservoir is now empty. I now have a parallel parking fluid mark on the road! Last checkup was at a specialist garage two months ago during a major service & inspection. They reported a 'minor weep', said its ok and replaced the power steering belt.
I searched the forum, got the Clarks garage steering diagram and took off the undertray. The cooler pipes look very corroded and covered in fluid.
1) Is there a better test method than refill the fluid, start engine and watch where it sprays?
2) How can I check if the power steering pump is still ok?
3) The fluid has gone over everything near the pipes, cooler and pump. Does this fluid cause damage e.g. to rubber bushes?
4) Replacing the cooler pipes looks tricky for me. Are there any instructions, other diagrams around?
5) Is it a simple fix any garage can do or should it require a Porsche specialist?
6) Can I turn off the pump to drive it to a garage? Remove or cutoff the belt? I do not want to leak fluid on the road nor damage the pump.
7) Anything else usually worth replacing during a steering pipes etc repair?
All advice appreciated.
Cheers.
1990 944T
Cheers.
1990 944T
