Tow bar warning light.
- Thread starter crossbro
This occurred on both a dealer fitted and factory fitted tow bar.
If this doesn’t cure the problem then it has to be the sensor or the bar requires a slight adjustment.
Hope it helps.
6DW said:I have found that when you deploy the tow bar from its ‘hidden’ state, I have to hold the rocker switch down for an extra few seconds to ensure its in place, otherwise I get the same message.
Hope it helps.
Same here, this seems to be the solution.
