TPM Problems
paul champion
I have a 2006 997 CS fitted with TPM. Now the manual states that for 19 " summer tyres the pressure should be 2.2 bar front and 2.7 bar rear. However, I have checked that the on board computer menu settings reflect these tyres, and when the computer checks the tyres from cold, they show 2.1 bar front and 2.5 bar rear. It does not state to add air, if anything it shows the front as + 0.1 bar! Which is correct? I have taken it to Porsche Silverstone, who reported no faults via diagnostic check, and that the manual maybe wrong and go by the on board computer, if there was a problem it would show 'add air'. Is it just me or is there something wrong here? Thanks.
ORIGINAL: paul champion
Because the TPM also takes into account the outside temp, tyre temp and barometric pressure
As above. The correct pressure should be set at an ambient temperature of 20C, not the lower levels we're currently experiencing.
So the sensors are estimating that at 20C the pressures would be correct, otherwise your tyres would be overinflated.
Thats exactly what mine shows when starting the car...
I wrote about it in the Porsche Post register column as mine has stated to add air as the air temperature had started to rise slightly..
garyw
Just a thought here guys, but that must be calibrated to estimate for air. So what if you fill with Nitrogen, which has a much lower rate of expansion?
Thanks for your replies - so when the outside temp is about 20 C, that's when the on board computer should show tyre temps as per manual i.e. 2.2 bar front and 2.7 bar rear?
Correct assuming you haven't driven the car ie the tyres are warm.
Paul,
The recommendation is for tyre pressures to be checked at an ambient temperature of 20deg. C.
Lower temperatures will produce lower tyre pressures, so you may need to make allowances for this.
I tend to regard the TPM as a guide only and find it most useful for alerting me to the possibility of a puncture when on the move.
For accurate measurement, I normally use a good quality analogue gauge with 0.1 bar graduations.
There's quite a bit on the forum about the use of nitrogen fill rather than air. It does reduce fluctuations in pressures and seems to maintain those pressures for longer.
Regards,
Clive
When I've been driving the car (ignoring outside temp) my reading will be 2.3bar & 2.7bar
garyw
