Hi Andy, 911's do tend to take the centres out of the rear tyres. This can indicate over-inflation, but is also due to the tyre "growing" under acceleration, similar to what happens to drag racer boots as they move off the line. You could try reducing by a couple of pounds to see how this feels, alternatively you could drive a bit faster to heat up the rubber! [
] On the circuit, tyre temps. are usually taken at the inner. outer and centre of the tyre contact patch. In this way, engineers can get an idea of how the geometry is working over a lap and can then dial this in to obtain optimum performance. [
] Regards, Clive.
TPM
- Thread starter Lancerlot
On changing my P Zero Rosso tyres back to Corsas recently I had the impression that the centre of the rears was wearing suggesting that they had been overinflated.
The information on the door jamb for the correct pressures is based on 20 degrees C .
In our cooler climate should the UK pressure therfore be 0.1bar or so less when cold and what is the role of tyre thermometers as used by the racing fraternity to inform them of correct inflation and geometry issues?
Andy
Andy
