Peter, a prospective member needs some help:
My problem is that after almost two years of getting the car back on the road I now have a problem that the ignition light forr the battery/alternator does not come on with the ignition start and the engine does not switch off with the ignition. I have taken the dashboard dial apart and tested the bulb and its contact on the backplate and had the alternator off and the starter motor connecting wiring but all to no avail. The earthing cable for the alternator to the engine block 'looked' a frayed type of flexible gauze which stupidly I did not remove - it looked quite oily and my next move is to try a separate earth to the engine block or remove the existing, clean it up and replace it. My question is how likely is this likely to be the problem.
The Bosch alternator is charging on the dash dial at about 14 as it is supposed to - but interestingly enough the car did switch off at ignition for a few days before I realised that the alternator was not charging - I gave it a tap with a hammer in case it was jammed and it started charging staright away BUT then would not switch off again!!
Could an alternator show charging ok even if not adequately earthed to the engine block but still not adequately earth through this strap to ground the warning light and light it up? If it is the alternator trather than the earthing of it could you advise where I could obtain a refurb kit for it to have a go at it myself?![. [FONT=verdana,geneva"] [FONT=verdana,geneva"]](/forum/styles/default/pcgb/space.gif)
