Hmmm, I don't have any specific experience of adjusting the compression ratio on a 924 as the 924GT really will not take any increase in compression ratio. Having just specced up custom pistons & rods for my 944T for a decked block I have become reasonably familiar with the issues and calculations concerned. Lets start off with the basics
Combustion chamber volume = swept volume+piston dish volume+gasket volume+head colume
Compression ratio = (piston dish volume+gasket volume+head volume) / combustion chanber volume
Deck height = distance from top of piston to top of block......if the piston stands proud, then that's a negative number
There are two targets that you will be aiming for. The first of those will be compression ratio. The higher the compression ratio, the more power and heat will be generated and the easier it is for the car to get into detonation issues - of course you can start changing ignition timing as well. The second of these is the distance from the top of the piston at TDC to the base of the head, gasket thickness is critical here. This is called compression height.
Remember that you will be performing a cold calculation here, the distance will be different at 6500 RPM when hot. A general rule of thumb I have been given is that this should not be less than 1mm. Having said that, one engine builder I know will build the engine, dyno it at 500rpm more than max, strip it, deck the block again, rebuild & dyno again until there is evidence of piston / head contact and then machine the top of the piston to suit. That's way beyond the level I operate at.
The engine I have had built did have negative deck height & there were no concerns about a piston hitting the gasket, though I am using a MLS gasket. If you don't already know it, number 4 cylinder is the one that you will experience detonation issues / head gasket problems on.
Hope that helps................ I'm writing from a position that now I at least have an idea about how little I do know.
