TQ: Ignition switch
PaulHere
Question from member:
924 lux 1979
How do i replace the ignition switch in the 924? Having starter problems - sometimes turnsover properly, sometimes nothing, sometimes slow turn then starts to turn properly without the switch being moved. I think the switch is the problem.
47033
Have a look at my post of 6/3/2005 about ignition problems which should give you the gist of where the problem lies - and how to fix it (probably). [;)]
If you need more let me know . . . .
I did this back in '93
  • remove wheel
  • undo the shroud(s) around the column switches
  • unplug/ remove switches
  • undo 6mm clamp bolt via hole underneath dash
  • slide casing off steering column
  • unplug multiplug
  • remove single securing screw to slide switch out.
