My experience with 15s is limited to the old PZeroCs. I still have a set of part worns that I can't give away! I got mine at very good prices and there may still be some around.
I like the Dunlop DO1Js I am currently using. They have the stiffest sidewall of any tyre I have experienced and give great turn-in. Not sure of the sizes for 15s though. They are also a little less good in the rain.
You can certainly get Michelin Cups for 15s and experience on a lightweight 2.7RS has been quite encouraging - wet and dry. They need more pressure in the wet to open the grooves up.
I think the Toyos may be worth a try if the price is right. They have a good track record for R-compound tyres. The RA1 was a very good tyre by all accounts, so the new 888s may be the business. There is also a new Avon track day tyre that looks very like the 888 in tread pattern which may also be worth trying.
Please let us know what your end with, your likes/dislikes.
Just, BTW, I don't know what your replica wheels are like, but I guess you know that the replicas are not as strong as Fuchs and are prone to cracking. I had 3 piece Compomotive fuchs replicas and one cracked and the rim sections came apart when some connecting bolts sheared causing instant tyre deflation and a harmless spin. Now quite what happened first in that little sequence and what started it all is a mystery, but I would not use them again on track. YMMV, but it is worth getting some crack testing dye and carefully checking the wheels.
I am also curious why you are choosing to run 15s not 16s? I understand the gearing advantage but in my experience it is not worth anywhere near as much as the ability to run 225/245s on 16s. The extra grip, particularly under braking is significant. Is there something else I have missed?
HTH
Richard
