Track Use
- Thread starter oldtimer
6 pot 350mm front brake upgrade (as GT3 MK2)
Front strut brace
Extra set of wheels with Pirelli Corsa tyres
My car is on factory sport suspension -20mm with LSD. I believe adding a little more negative camber would be benificial but have no plans to do so for the moment.
david_yorkshire
Done 3 trackdays sofar with the S - loving it !
tyre pressures (pzero) much lower than road, (29psi all round cold, I think) made a massive difference - this was advised by Parr onsite.
David
Re: tyre pressures - Yes, lower pressures required. I find reducing to cold road pressures for track hot gives good results.
Julio Geordio
Tyre pressure is a key requirement, on my PS I was told 32 + 36, normal road conditions 34+40. Make sure you inflate them back, I had to leave quickly at Brands and found myself driving a gondola back to London. You can change to Cup tyres, but I prefer to have a homogeneous setup with no understeer and a solid car rather than outright grip / lap records. Clearly I will say the opposite in about 6 months when I want to upgrade again!
I do not like PASM that much, but this is me, I am therefore fitting progressive springs, decided to see what difference all this makes before fitting struts/...
Brakes are fine, changing my pads to Pagids just to try, puttting on breaded hose and replacing the brake fluids. I can always fit larger ones in the future.
Anyone know whether you can retro-fit the LSD by any chance?
Andy
Andy
david_yorkshire
Wish I had the money for both !
ORIGINAL: johnag007
Humm, not sure I like the sound of this modification, don't the crumbs make the disks squeal ?
but I suppose some hot toast to eat after a few laps is nice.
Sorry, mother tong is French, I can express myself much better in that language...javascript:void(AddText('[]'))Humm, not sure I like the sound of this modification, don't the crumbs make the disks squeal ?
Andy
oldtimer
Have now done Donington and Oulton Park this year in the 997S. Running Pirelli PZero Rosso's and trying to keep pressures at 2.2 front / 2.6 rear or 33/39 in old psi units as per manual for 19inch tyres. I think that the rear is very sensitive to pressure - my car felt better with 44 psi than 39 - maybe just what I'm used to.
The Rosso's are fine but feel a bit soft on track , think stiffer sidewalls would be better. Standard OEM pads do not have same 'bite' as Pagids , I was having to brake earlier at Oulton than I'm used to. The power's good , and the 6 speed box is much better than the ancient 5 speeder in my other car.
someone should redesign the sport chrono user interface - you have to work the OBC lever as well as press the PCM knob and look at 2 different readouts while trying to keep the car on the black stuff - not fair to pensioners ![]
